Old 11-12-2003, 07:02 PM
WillyC WillyC is offline
Default Re: Seacraft Surgery 2
Fellow-Ship,
Just curious what your plans are for paint/gelcoat on the hull of your boat. How difficut was the sanding process to get back to the original gelcoat? I have a 20' CC and am considering sanding the hull to get back to gelcoat and then repainting.
Thanks - Will
Old 11-13-2003, 10:02 AM
Ha Strick
Now that the boat is done the memories are all good but when I was doing the boat (150 days of work) there were a few days of frustration and just pure hard work. After I got done I realized that if I would not have put a time of completion date on the project and if I would have bought more beer I probably would not have had any frustrating days at all.
Ha Will
I have been in the water for approx 1 ½ years not I painted both the inside and out with Sterling two part marine paint with the roll and tip method works pretty good. As for the sanding process I went through two orbital sanders from Sears and approx 5-7 days of sanding to get right. I would do it again if I had to. The old paint was a car enamel and I had major concerns about painting over it.
http://www.theboatzone.com/gallery/fs01
FellowShip [img]images/icons/cool.gif[/img]
Old 11-14-2003, 08:40 PM
jimgdane jimgdane is offline
Hey Fellow ship
Congrats on fine looking vessel...
I understand you used Sterling's urethane - what color is that ? and also which product did you use for fairing and as hi build primer ???
many thanks and best of luck with her
regards
jim dane
Old 11-17-2003, 09:58 AM
Ha Jimmy
I think it was called Blue Mist I would have to look at my chart or old can’s of paint to confirm. As for the fairing compound I used the West Systems fairing compounds I used several types depending on if I was doing heavy glass work or top finish fairing work. I used the Sterling two part primer first before I painted both inside and out of the boat it sands very well before you paint over it. I would use a foam roller with the primer process, when you use a paint brush you usually will make streaks that will have to be sanded more aggressively to get even.
