Old 12-05-2003, 10:12 AM
Default Re: Hard Top Complete
I am waiting for a quote for a new hardtop and enclosure for my '78 23' Sceptre - I'm sure will be exorbitant and not likely to come out nearly as well as yours. I am very impressed and very very jealous. Good luck and keep up the great work - can't wait to see this boat when you are done.
Chris
Old 12-05-2003, 11:07 AM
abl1111 abl1111 is offline
Chris,
Let me know what that quote is, if you don't mind. One day 'down the road' I wmight want a hard top too. Right now, I am in the throws of sanding and galssing and sanding and glassing and...
You get the idea. I tell you, re-doing a boat like this is a full time job !!! my mind is always thinking about different aspects of the project; from the exact type of electrical switches to use to re-fitting new tempered glass.
It is nuts!!! I mean, I am nuts !!!
Old 12-05-2003, 06:59 PM
Once again thanks for the complements fellas.
Don- the electronics box measures 24"x24" at the bottom. It angles up to 32" wide and 27" long were it attaches to the hard top. It is 10.5" deep. I usually use the e box for storage rather then actually putting radios etc up there. Not sure how we are going to attach the legs yet but Fishing Boats Unlimited (San Diego) says he will make it work. He usually makes a ring that fits the perimeter of the underside of the hard top that the legs attach to but I would rather have the legs attach directly to the hard top with some backing plates on the top side. My plan was to make it look as close to the the Yellow Fin hard top as possible. I realize that this is alot of stress to place on the Consel but my plan is to really beef up the inside of the consel with more laminate and composite before attaching the hard top to it. The consel would then be laminated with epoxy fillets to the deck. After I get the fuel tank out of the boat I plan on epoxying some fillets from the underside of the deck to the stringers around were the were the consel sits. After all that it should be sturdy. I wanted a big hard top and yes I was thinking of getting a canvas enclosure made for the winter time. What do you think?
Strick
