Old 12-06-2003, 02:51 PM
ScottM ScottM is offline
Dieter Sprockets
Default Re: Cavitation plate
Capt Brad,
I've always been told the cavitation plate should be even with the keel. Is the engine running up to proper RPM? Have you changed props? Only used it twice since the restore - bad gas/water in the gas maybe? Is the fuel line clogged? Spark plugs fouled?
By the way, have you talked to that Creole voodoo woman yet? The way the weather is rippin' up here, I think you must have.
Old 12-06-2003, 09:28 PM
ocuyler ocuyler is offline
I think you're supposed to take the boat off the trailer...
Otto
Old 12-07-2003, 09:32 PM
TUGBOAT TUGBOAT is offline
[img]images/icons/shocked.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 12-08-2003, 08:59 AM
RS RS is offline
Originally posted by Capt. Brad:
I was only able to get Her up to 34 + -.
(GPS) She even feels sluggish . I was getting a good 43 + - before. . .What could it be ? [img]images/icons/cool.gif[/img]
<font size="2" face="Verdana, Helvetica, sans-serif">Are you using the same gasoline that was in the tank before the rebuild? If so, it may be the culprit if it is a few months old or more. I had the same situation with old gas.
Also, the cav plate is probably not the issue. In fact, as long as you are not getting cavitation in normal operation or the prop is not breaking away in turns, higher is usually faster.
Best regards,
Roger
1979, 20' Master Angler
Old 12-08-2003, 04:23 PM
Thanks, New gas,same prop, Same everything(well rub rail). I think the oil Mixture was way off,too much ? My tach did not work [img]images/icons/frown.gif[/img] so next outing I'll be able to get that. It didn't sound like I was pushing the RPM up enough. The linkage ? I'll change the plugs use a lil less oil mix & Hold On ! [img]images/icons/grin.gif[/img] I just thought i remebered the cavitation plate being even now its an inch + higher than before.
Scream' Reels [img]images/icons/cool.gif[/img]
www.frenzie.com
Old 12-09-2003, 11:45 AM
JohnS JohnS is offline
Let me know when you are going to go out again and we will hook up and see what the deal is. Only 34???? Something is up. I will put my boat in the water and run down to Homestead Bayfront and meet up with you.......might even tow down to there and put in because the channel is WAY shorter than Black Point.
Hope you won't mind when I blow by you at 60!!!!
John
I support the "Hot Boat = Hot Chick" theory.
Old 12-09-2003, 07:09 PM
barnacle barnacle is offline
Years ago it was even with the bottom. Today everything is mounted from even to 1" above the bottom. The higher you get it the faster it will go. Rember to keep the water intakes below water level while running at high speeds. The only problem with it being up 1" is that it big seas it may not stayed hooked up. You need to know what your rpms are before you start anything.
