Re: Inboard hydraulic steering setup
Hey Jeff, thats the one I ordered. I just checked it in my boat us catalog. They have all the specs on the different helms and cylinders combinations. Any other questions I might be able to help with let me know. I did have a little trouble getting it bled down and it is a messy job to boot.Routing the tubing I ended up having togo thru the same hole on the starboard side that wiring etc, goes thru and then down centerline in order to make it fit/work good. My bilge blower on the port side also had to be moved slightly to allow the cylinder rod to move. Good luck- you will be very happy you did it,I was. [img]images/icons/smile.gif[/img]
