Old 01-04-2004, 02:14 PM
cc cc is offline
Default Re: fuel tank sending unit
I suspect the sender is all the way down when you have used 5 gallons. Sounds as if the sender length or the float arm was not long enough to allow the float to travel in an arc from full to empty as the fuel is used. If the float arm is too short, it will read from full to empty in only a very short range.
