Old 08-23-2002, 09:17 PM
Scott Scott is offline
Default Re: 1989 23' Seacraft.
Hey Rich
When the water that came out of the transom .... did it stop or just keep dripping till you put the hardware back???
and how long have you noticed the waterline disappearing???.....Any chance your foam filled stringers are wet???
I ask as a 23 SeaCraft that was restored down here had a similar problem (not sure about any water line changing however) but the transom was wet(this was an I/O) and when they started the work the guy told me that five to six …5 gallon buckets of water were recovered as it drained out of one of the stringers.....he said it just poured out. They did nothing but got the bulk of the water out, let it dry as best they could and then finished the transom.
I never found out how they thought the water got in there ... however it was over some time. The whole point is that this was about 200Lbs of water that could affected the trim of the boat.
You may want to drill some holes in the stringers (I think Fellow-Ship went through this exercise) down low to see if there is water in there..
Hope this helps!!!!! [img]images/icons/wink.gif[/img]
Scott
