Old 08-27-2002, 07:16 PM
rsegreto rsegreto is offline
Default Re: 1989 23' Seacraft.
Hey John R-
I keep the boat right on the river there. I'm on the Pawcatuck side over at N.W. We go to Napatree quite a bit, it's one of the nicest one day boating places around, as you know I'm sure.
Take care-
Rich [img]images/icons/wink.gif[/img]
Rich/Westerly,RI
Old 08-27-2002, 08:45 PM
John R John R is offline
It's also one of the best night surfcasting places too [img]images/icons/grin.gif[/img] [img]images/icons/wink.gif[/img]
Surf and Boat fishing for
Striped Bass
Old 09-30-2002, 02:34 PM
Bigshot Bigshot is offline
I would not necessarily worry about the transom rot. You will experience cracking(especially) in the corners if she is fllexing. You will get cracks way before it gets critical. Point is that it may not be anything to worry about. Your scupper thing is something to look into because your transome could not hold that much water to make it list. You may have some water trapped somewhere. Then again it may have always been that way. My Hydra-sport started to list to starboard. It was becaiuse the 2 batteries on that side were replaced with 2 that weighed about 20lbs more. Just enough to change it's attitude. This winter unscrew any screws in the transom and inspect again. Make suer you are using a good sealent when you put them back in.....in the spring. Let it dry out all winter and see what gives.
regards......Nick
Old 10-01-2002, 03:41 PM
Hello Mr. Bigshot! (Nick)-
Thanks for getting back to me, I appreciate it. I intend on pulling out all of the screws on the transom when I pull it out of the water this week. Hopefully all that it is, is a little trapped water and that's it. I hear one of the best sealants to use is the 5200 series, I'm going to give it a shot in the spring. Should I leave all of the screws out for the winter to try and drain the water out or is it only necessary to this for a few weeks? Let me know if you or someone else can help me out with this.
Thanks in advance.
Rich [img]images/icons/wink.gif[/img] <blockquote><font size="1" face="Verdana, Helvetica, sans-serif">code:<pre style="font-size:x-small; font-family: monospace;"> </pre></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Rich/Westerly,RI
Old 10-02-2002, 03:06 PM
Leave them out if it will stay dry. In the spring see if still wet. If so try a few drills in surrounding area if you can conceal it later with epoxy and bottom paint. Most rot will be under the waterline unless you have cracks above. Water intrusion takes longer than you think but once she rots.....oooofffa!
regards......Nick
