Old 01-31-2003, 06:32 AM
CRO CRO is offline
Default Re: FUEL TANK REMOVAL
I just started to take the tank out of my 73 23 Tsunami and it dose not apear to be fomed in. I just drained the fule out last night and this afternoon I am going to try and remove the tank. What do you do with the fill hose to get it out of the way? Also how do you put in a new fill hose? Thanks for any info. Chris
Old 01-31-2003, 04:18 PM
AFTER YOU DISCONNECT THE HOSE FROM YOUR TANK YOU CAN UNSCREW THE GAS FILL BRACKET THAT IS MOUNTED ON THE CAP OF YOUR BOAT PULL THE HOSE UP ABOUT A FOOT OR TWO DO THE SAME THING WITH THE AIR EXCAPE HOSE THEN THERE SHOULDN’T BE ANY TROUBLE REMOVING THE TANK EXCEPT FOR THE WIRES FROM THE GAS TANK TO YOUR GAS INDICATOR AND A GREEN GROUND THAT MIGHT GO FROM YOUR TANK AND YOUR GAS FILLER TO A BOAT GROUND. AS FOR INSTALLING A NEW HOSE FIRST OFF MAKE SURE YOU BUY THE GAS TYPE HOSE NOT THE WATER OR EXHAUST TYPE HOSES IF YOU REMOVE THE HOSE CLAMPS FROM THE GAS FILLER YOU COULD ATTACH THE NEW HOSE TO THE OLD ONE BY USING SOME LARGE PVC PIPE WITH HOSE CLAMS HOLDING THE OLD ONE TO THE NEW TOGETHER. THEN JUST PUSH IT THROUGH. MAKE SURE YOU USE 2 GOOD HOSE CLAMS ON BOTH THE TANK AND ALSO THE GAS FILL JUST INCASE ONE BREAKS. THERE IS ONE LAST THIN TO DO WHEN YOU RUN THE NEW AIR EXCAPE LINE MAKE SURE YOU HAVE A LOOP IN THE LINE LIKE A U JUST BEFORE YOUR OUT BOARD VENT BY DOING THAT IF ANY WATER DOES GET INTO THE LINE FROM THE VENT TAKING IN WATER IT WILL NOT HAVE ACCESS TO YOUR GAS TANK IT WILL GET CAUGHT IN THE LOOP. WHEN YOU FILL YOU TANK WITH GAS IT WILL GET BLOWN OUT THE VENT.
FELLOW-SHIP [img]images/icons/wink.gif[/img]
Old 01-31-2003, 06:22 PM
cSickNick cSickNick is offline
FYI,
Shop around for that fuel hose. I found prices between $9 to $6 a foot.
Same hose, different thief ...
- Nick
Old 02-04-2003, 04:21 PM
Trayder Trayder is offline
Velvet Jones
Check out these guys:
Surplus Unlimited
Awsome prices on 2" fuel fill hose $5 a foot and amazing prices on marine wire. All Marine quality, they have been very realiable for my needs.
