Old 02-11-2003, 08:03 AM
jw jw is offline
Default Re: Raising the Floor?
I too had water problem form those damn cockpitdrains in the 20sf. I have cut the tubes loose, filled inthe holes thru the bottom and will just drain the cockpit to the bilge. Also adding a 1100gph auto bilge pump. Perko make a plastic fitting with a 90 hose barb, lookslike a kitchen sink strainer, that should fit right in the deck scupper, I plan on running the hose straight to the bilge.
JW
www.bansheecharters.com
Wishn' I was Fishn"!!!!
