Old 07-31-2003, 09:53 PM
Roland Rodriguez Roland Rodriguez is offline
Default Re: OEM Steering for '73 20' CC?
The problem with the cable steering is that you have to replace the system every couple of years if your lucky. If the boat sits for a while it destroys this type of steering. If you go the hydraulic route you will never go back. I have a 20 footer with a 225 and can steer it with 1 finger. If cost is an issue, down here in south florida you can pick up a used helm, resevoir, and piston ram. for about 300.00. Hope this helps.....been there and done that.
