Hooper,
I am sorry to hear you are having a problem with your Trim Tabs. Do you know how old the system is? Our systems carry a 5 year warranty but we often can fix it for little or no money well after the warranty period. That '70s boat is correct about how to get the Tabs to come up without power. From your description it sounds like a switch or connection problem. Take a look at step # 3 below. Pay particular attention to the green wire since it is the one that controls the starboard valve. Also look carefully at he back of the switch as a loose or missing screw could give the same symptoms. Let me know what you find and I will get you going! Tom McGow Bennett Marine Fluid: Automatic Transmission Fluid (ATF) any type. Hydraulic Power Unit is self bleeding, running the Trim Tabs up and down 3-4 times will purge air from the system. Fuse: 12 volt system use 20 amp in-line fuse on positive. (24v & 32v use proportionately smaller) Red= Port Valve Green= Starboard Valve Blue=Motor Forward (pump pressure) Yellow= Motor Reverse (pump retract) Black on HPU=Ground Orange on Helm=Control Positive Troubleshooting 1.If one side is not operating reverse hydraulic lines on the front of the Hydraulic Power Unit to determine if the malfunction is in HPU or actuator / hydraulic lines. If after reversing the lines symptom shifts to the other side the malfunction may exist in HPU. If the symptom remains on the same side, malfunction may exist with the actuator / hydraulic lines 2. Is the unit receiving a solid 12 volts? Low voltage will some times cause the solenoids to not open preventing the tabs from moving even though the pump motor is running. 3. Conduct the following test: Remove the wires from the helm control and touch together as follows: Operation=Reaction Orange (+), blue, red= Port trim tab down Orange (+), blue, green=Starboard trim tab down Orange (+), blue, red, green= Both trim tabs down Orange (+), yellow, red= Port trim tab up Orange (+), yellow, green=Starboard trim tab up Orange (+), yellow, red, green= Both trim tabs up If the trim tabs function correctly for each wire grouping then the switch is at fault. Also note that any loose or missing screws on the back of the switch (whether a wire is connected there or not) can cause the pump to malfunction. This test may also be done right at the pump by substituting a "hot lead" for orange. There is usually a connector to the wire harness within a foot or so of the pump. You want to check this connection for corrosion. You may wish to cut the connector off on the pump side and try the test on bare wires. 4. If you suspect corrosion on the wire connector near the pump, cut it out, test as above and reconnect using butt splices. 5. If you conclude the problem is in the pump, contact me. Bennett Trim Tab Systems carry a five year warranty. We also offer a trade in program for units out of warranty. Contact us for further details after you troubleshoot the system. 6. Check to see if there is a relay in line on the wiring harness near the hydraulic power unit. If there is it is an Interrupter Relay (IR1000). It prevents the system fuse from blowing if you try to actuate one trim tab up and the other down at the same time. After you test as outlined above, try removing the relay from the wiring harness and retest the unit. If it works the IR1000 will need to be replaced [ August 03, 2003, 07:32 PM: Message edited by: Tabman ] |
