MY 23' 1974 HAD A I.O, IT NOW HAS A EVINRUDE 225 ON A STAINLESS MARINE BRACKET W/ A FULL SWIM PLATFORM. I HAD THE TRANSOM REDONE 2 YEARS AGO & PUT A TUNA DOOR IN IT I LEFT THE ARCH ALONE STRETCHED THE DECK ALL THE WAY BACK TO THE TRANSOM about 6",, left just enough room for cables, fuel lines & such. THE CAP OF THE TRANSOM HINGES FORWARD TO ACCESS A STORAGE COMPARTMENT FOR A REAR ANCHOR, OIL JUGS, FLARE KIT,& THE WATER FILL CAP WITH PLENTY OF ROOM TO SPARE. never enough room in a small boat for stowage. IN HINDSIGHT I DONT THINK I WOULD HAVE DONE IT ANY DIFFERENT. IT HAS A CLEAN & SIMPLE LOOK . I GOTTA THANK MIKE A WILDFIRE MARINE IN STUART FLA . THIS GUY IS A GREAT CRAFTSMAN & HAS REAL GOOD IDEAS HOW TO CUSTOM DESIGN A BOAT FOR PERSONAL WANTS .MY PERSONAL PREFERENCE IS A CLASSIC IS A CLASSIC WHEN IT LOOKS LIKE A CLASSIC. BUT THATS JUST ME . I GUESS IT CAN ALWAYS BE CHANGED BACK ? ? ?
STRICK, I'M CLOSE TO COMPLETING A 23 WITH AN ARMSTRONG BRACKET/250HP MERC. IF YOU OR ANYONE CAN EXPLANE HOW TO SCAN MY PICTURE'S, AND POST THEM(I DON'T HAVE A DIGITAL CAMERA),I'LL BE GLAD TO. I'VE DONE A LOT OF CUSTOM WORK TO IT,, I LEFT IN THE THE CROWN. I JUST TONED IT DOWN A LITTLE BIT. FINISHING THE CAP WITH THE CROWN-OR WITHOUT IS THE SAME AMOUNT OF WORK EITHER WAY. DO IT THE WAY THAT YOU THINK LOOK'S THE BEST. SAY,,, WOULD YOU BE THINKING OF USING A CHAINSAW FOR ANY OF YOUR MODIFICATIONS? [img]images/icons/grin.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/grin.gif[/img] HEH HEH,, JUST A HINT HERE SINCE NO ONE ELSE BROUGHT IT UP STRICK O'LE BOY,,,,, MULTIPLY YOUR ESTIMATED COST OF THE REDO -X-2 FOR AN ACCURATE COST ANALISYST, FOR THE BEER THAT WILL BE CONSUMED THROUGH THE COARSE OF THE PROJECT..... TIME'S 3 IF YOU SOLICIT MANUAL LABOR FROM ANYONE ON THIS SITE. GOOD LUCK. TITE LINE'S TO ALL LT DAN
Hey LT - I can't scan pics for you but get me the digital one and I'll throw them up on the web... Looking forward to see how much you've cut up your boat [img]images/icons/grin.gif[/img]
Surf and Boat fishing for Striped Bass http://striped-bass.com/images/sb_small180b.gif |
John ..... the signature [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img]
Hey fellas
Great responces back. Right now I'm still pulling out the rats nest of wiring and cables that is on this boat. Neither of the bilge pumps were fastened to the bilge they were just "sitting" on the bilge. Also there was a lot of household electrical wire used.... you know the real stiff stuff. Every screw was of a different length or diameter.. at least the guy put SS screws in. There are some 1/4 inch plywood shimes that shim the gas tank between the stringers and most are rotton or loose. I'm going to remove the gas tank and most likely replace it unless someone convinces me otherwise. What would you guys do? It works fine and has no leaks.. however it is as old as the boat [img]images/icons/frown.gif[/img] I'll be using the reciprocating saw instead if the chain saw for most of the grunt work [img]images/icons/wink.gif[/img] I'm probably going to keep the consel I have and just modify it to the way I like rather then buy a new one. What the heck it is big and sturdy and my kids just love jumping down into the compartment [img]images/icons/smile.gif[/img] Also thinking of ways to keep the arch and incorporate it into the design I have in mind. I quit adding up receipts for these restore jobs after my first boat because when I added it all up it was cheaper to just buy a boat already rigged then to restore. But I love working on them which is why I spend the money. As you all know anything boat related is going to cost you $$$$ I just bought a electric start kit for my 15hp merc 4 stroke kicker.... the little tiny starter alone was $400.00 Can you believe that!! LTDAN I dont do much scanning however you could take some new pics of your rig and have the developer put them on a disk and then transfer them over that way. I'm still trying to figure out how to post pics directly to this web site without making a link like I have been doing. Strick
Strick....While you have access DO make sure the fuel tank is ok and or replace it .... Then take a look a the deck the tank sits on. While mine seemed ok ... with the tank hiding most of it ....IT WAS NOT....It was broken away from the attachment points at the stringers and much to my dismay the plywood deck that looked to be encased in fiberglass was not!!!! [img]images/icons/rolleyes.gif[/img] the underside of that deck was UNPROTECTED RAW PLYWOOD ....I was rather surprised at that ... needless to say it was rotten
Display Modes | |
