Old 11-18-2003, 07:40 PM
EBEACH EBEACH is offline
Default 130 HP 1996 Yamaha Saltwater Series
FOR SALE
130 HP 1996 Yamaha Saltwater Series engine
Includes:
Stainless Steel Prop
Multifunction Tach and harness
Remote oil tank with factory metal holder.
Main engine control harness
Shift and throttle cables.
Price is $3,200
I’m selling this because I bought twin engines and I’m only using one of the engines. For sale is the right engine (standard rotation). It’s still in a steel factory shipping crate. Reported to have less than 400 hours on it. Prior to making the purchase last November, I had a Yamaha mechanic check them out. I have the report from the mechanic and reads:
“Compression is 150 +/- 5lbs. Check compression and inspect cylinders, visual inspect steering arm, shift shaft & trim motor. Test run both engines listen for knocks or bearing noise. Both engines run & sound solid. Steering arm, trim motors & shift shafts all in good usable shape.”
I was going to keep this motor for a back up, but the engine I installed is running great, and I really should sell this before it depreciates further.
