Old 04-05-2004, 02:21 PM
gw204 gw204 is offline
Default Re: Wash / Livewell pump - unwanted water flow
Here's my setup:
Clamshell scoop -> bronze seacock -> reinforced hose -> strainer -> reinforced hose -> Shurflo Blaster pump -> garden hose w/ cheap plastic nozzle.
It doesn't leak one bit while running or with the pump turned on and the nozzle closed.
I ran the garden hose directly to the pump as I was in a hurry and didn't have the time to determine where I wanted to mount a spigot.
Fix or replace your cap and you should be OK.
Brian
1981 Mako 17
