Stoney
The water is more likely than not, holding under the fuel tank in the bilge. Your boat being level while at rest in the water does not allow this amount to flow aft to be pumped out by your pumps ![]() ![]() Generally there is a small space between the front of the fuel tank and the back wall of the forward deck hold. I was able to cut through this wall and install a 15-gallon fresh water tank. I then installed a watertight hatch in the cut out space. You possibly could do the same and install a pump in that space ![]() Just a note of caution, I hope the underside of the wood shelf that supports your fuel tank has been glassed or the excess water accumulating in the bilge area could cause you problems ![]()
