Old 10-10-2004, 12:04 PM
RS RS is offline
Default Re: Instrument panel questions
I am wondering if 1/4" is thick enough to support all gauges, radio and fish finder/gps? Or should I go to 1/2"?
The problem with Starboard (or Seaboard) in the length you need will expand and contract quite a bit (about 1/32 inch per linear foot over a 40 degree change). The contractions in the winter will cause the corners to crack where fastened(been there, done that). I suggest some 1/4 inch plexiglass. It is more rigid and thermally more stable.
Best regards,
Roger
http://members.cox.net/rhstg44/Misc/...go%20small.jpg
1979, 20' Master Angler
Old 10-10-2004, 07:18 PM
1/4" is definitely to thin- 1/2" i used has done really well. i havnt had any shrinkage problems (with the startboard) so far. I took the old original panel to the plastics place and they shaped it identical to the original. Also made all the other cuts i wanted for no charge. If I might add, make yourself a template first and try different layouts until you find one you like. Your original thought might end up not being the one you choose. I found that out the hard way. Also allow yourself room for expansion as far as electronics go if you think you might upgrade. Or end up doing what i did and redoing the whole thing,lol. [img]/images/graemlins/shocked.gif[/img] [img]/images/graemlins/grin.gif[/img]
good luck- anything I might be able to help you with just let me know- and we like to see pictures also !!!!! craig
Old 10-11-2004, 01:09 PM
gw204 gw204 is offline
When I work with large pieces of Starboard where the expansion/contraction could be an issue, I bore my screw holes slightly oversize so the panel has room to "float" with the changes in temparature.
Brian
1981 Mako 17
