Old 10-15-2004, 10:37 AM
rockdoc rockdoc is offline
Default Re: Diesel I/O opinions?
Botapeje-
Have you been happy with the Mercruiser? This will be my first experience ever (tomorrow!!) with an I/O, so I'm curious what your experience has been. Any advice?
That nice closed transom would be good with an outboard on a bracket.......
I'll wait and see how this Seafari with the gas I/O works out, and if I end up with a 23' later on I might go diesel, we'll see.
Steve
Old 10-17-2004, 01:06 AM
nestorpr nestorpr is offline
Hi Rickdoc,
Yep, Im satisfied with it for now, it needs some work since it's a bit hard to start after a couple of weeks downtime but it goes well after the first warm-up. Although, if I had the money, I would put the RotaryPowerMarine 240 Si engine in her. I did some investigating and found some good stuff about this engine, 240 hp, supercharged, twin rotor, all electronic ignition and fuel injection, The whole package weighs about 340 lbs and you could even cut the engine box down a bit because it'a a smaller package than the Mercruiser! I also found out that its gas mileage is better than a V8 pumping out the same horsepower so, let's recap: Powerful, Lightweight, Reliable, Fuel efficient, Mercruiser Barvo 3 drive, is this the way to go?, maybe, if I had $16,000! Still, any ol' outboard costs about that much nowadays and I can sit on the I/O engine box while fishing, something you can't do with an outboard. I know, I'm biased, but I've owned both types and stil prefer the I/O, we've lost too many big marlin behind the outboard powerheads when the marlin suddenly swerve behind the boat when trying to board them, lost 2 tournaments that way, one was a definite 300 and the last one was over 500lbs, on 50lb line they would have been shoe-ins.
Anyway, yes, I like the Merc and it still has 2 more rebuilds on it so it will probably be around a while. I suggest you keep it in tune yearly, new plugs, points, condenser, maybe even cables and dist, cap/rotor yearly (I do). Make sure the 3 fuel filters are always clean and replace them when you see your top end being affected. On this engine, low speed problems are usually electrical and high speed ones are fuel/air related. I just replaced all the electrical elements on mine, plugs, cables, dist. cap, rotor, condenser, points, and coil. No guesswork here! Next is a carb. rebuild and a prop repitch, my top end is still low. It should rev at about 4500 to 4800 and I'm only getting 4100, probably wrong pitch propeller. At this rpm I'm only seeing about 33 mph, should be more. BTW, also found out there's an electronic ignition conversion kit for this engine IF you still have the original distributor, which I don't. Too bad for me!
I just took her out today for a fishability test by myself and am happy to report that, with the Bimini down, I was able to fight a fish while controlling the boat simulateneously, usually you need a CC boat for that but this baby does it very well indeed. Caught 1 barracuda, 3 dolphin, and one bonito using 2 rods and still had no problems fishing, steering, or boarding the fish, and I still have a cabin when I feel the need to comfortably overnight. It's the best of both worlds my friend, enjoy your Seafari and I hope you put a thousand miles on it before you think of trading up to a Seafari 25!
Boatless again!
Old 10-17-2004, 01:30 AM
Botapeje- Thanks for that reply! Glad to hear you're happy with the merc. That RotaryPowerMarine sounds too good to be true, actually at $16,000 it is too good to be true for right now...
I had a fun day tinkering today, straightening things up under the engine box and in the cuddy, gas tank, etc. I really prefer working on in I/O, in the boat, as opposed to standing behind the stern working on an outboard. Something about being in the boat....you're boating....even if it is out in the driveway.
I sometimes fish solo, and I'm anxious to see how that works out. In the center console I can steer with my butt while fighting a fish; sometimes out in the rips with breaking waves it's a little crazy, but it works. One thing I've realized this summer is that level wind casting reels make fishing solo a whole lot easier, one less thing going on. This boat is going to open up some more fishing options, like white marlin, shark, maybe tuna.... darn, I'm going to need more rods and reels....
Steve
Old 10-18-2004, 12:25 AM
You're welcome! Hope you enjoy your boat as much as I'm doing mine (at least in between business trips!). I'm like you, love to tinker but I can't do much, in the place where I store my boat the EPA doesn't allow us to work on them and I don't have a place at home since I live in a townhouse and can't have the boat there. Maybe soon I'll move and be able to have her next to the house so I can tinker in the afternoons, she really needs it!
Don't worry about the rods, it's like a woman with shoes, you can never have too many! Good luck and keep the faith!
Boatless again!
