Jedjar
I had to cut the lip on both sides (about 1 inch in total }to remove my tank. No big deal as this has no effect on mounting the deck hatch. Measure the tank ( it's probably 28" give or take a bit, then the lip. Cut the lip opening about 1/8" wider than the tank to allow a small cushion of clearance when you lift the tank out. If you tank has small mounting tabs, cut them off as well. Get ready to replace the deck that the tank sit on as most get wet and soft over time. Dink |
Display Modes | |
