Hey guys,
I need to replace the plywood bulkheads and side coaming panels on my boat since they're very deteriorated by the sun and coming apart. I would appreciate any suggestions as to what material(s) I can replace them with that will be long lasting, look good, and hopefully not to expensive. Thanks!
Boatless again! |
Anybody?
Boatless again! |
I'm not sure what you're asking about. A few pics might get the creative juices flowing.
Best regards, Roger http://members.cox.net/rhstg44/Misc/...go%20small.jpg 1979, 20' Master Angler |
Good idea, here's what the cockpit looks like:
![]() As you can see the front bulkhead and the sides are made of plywood and varnished. The sun has really cooked off the varnish and the plywood is slowly delaminating. I would like ideas on a different material to use for this, thanks! ![]()
Boatless again! |
Check with Ben. Looks like he did a nice job with his bulkhead.
http://forum.classicseacraft.com/sho...=&fpart=1&vc=1 |
It was fairly involved but it will look great, i used the old ones as a template for shape and dimensions, then i cut the new wood to the basic shape, trimmed it to be perfect and but a layer of glass tape on the edges. then i measured where it meets the cap and overlaps on the top and bottom and routed it to the depth so it would sit flush with both. then put a layer of roven on the outside. after that i put it in the boat with epoxy and silca where it over laps and glased the sides to the hull/liner. the rest is all fairing, but i did this cuase it will look amazing when its all painted white. and on a bright note, i think ill be finishing the boat!!!! [img]/images/graemlins/grin.gif[/img]
no falls, no balls |
I redid my bolsters two years ago using PVC board for the backing and a good grade of vynl, they did not do as quoted by putting drains in them, but they did use a cloce cell foam. Looks good and fells good for about $750. 76 CC Inboard.
GARY 76 SEACRAFT CC INBOARD |
My bolsters are pine coated with two coats of epoxy. The vinyl covers 99% of the wood on the backside just the bolts are sticking thru.
Strick
Hey Gary-howgozit world traveler???? do yours go 360° around the boat or stop halfway up from the stern???
"Lifes too short to own an ugly boat" |
Hey-Craig, trying to stay home and yes I have them 360 around the boat. Do you have your boat on the hill yet?
Gary
Display Modes | |
