Old 03-16-2005, 04:35 PM
ocuyler ocuyler is offline
Default Re: Install leaning post
I think properly sized stainless steel screws bedded in 4200 or 5200 is sufficient. If you can get a nut on the bottom of the floor with a washer on a bolt, that's the way to go. I don't know about the molly bolt thing. If the floor is soft, you need to fix it...
The old holes should be drilled oversize and filled with a 2 part epoxy (West) thickened mixture. The repair can be finished with gel coat.
Otto
