Strick...
36" setback is not committed as of yet, I could always modify my design to be 30"...the setback distance is an open issue for me, although the Suzuki needs at least 24" to clear at full tilt. Of course I want to buy myself a little more room, so maybe 36" is a little overboard...but then, how is the setback distance measured? Is it measured from the motor mount, in a straight line, to the transom, or is it measured from the motor mount, to the bottom of the transom? I want to be comparing apples to apples, and maybe the dimension I am referencing from my design, is not the correct dimension. In any case, if I gave you a 30" engine bracket, to mount on the back of your transom, and the 30" was measured per the correct way (as I asked about above), and you had a 30" shaft O/B, what distance from the plane of the keel, would you mount it? Knowing that you would be safe, and any future adjustment would require raising the O/B...not having to worry about lowering it? Note: I have the manual (PDF file) of setting up the Suzuki DF250, and in this manual they provide a detailed drawing of all the dimensions of the O/B...so I don't really need the motor's anticavitation plate as a measuring stick, I hav it all laid out on CAD, per the drawing. So I know my dimensions are on the money...just don't know where to set my motor mount height for the desired setback, to get the floatation part of the bracket designed. I also plan to use my existing 24" trim tabs, so this will limit the width of the floatation part of the bracket slightly. Thanks, john
Any ideas, pictures, drawings, advice, or direction is always welcome...just email me: jrdwyeriii@aol.com |
Display Modes | |
