Looks like a project...thanks for the replies. Will most likely end up beveling and building it up, glass and plywood.
going to look like crap from the outside, but it beats a hull breach or failure of the deck plate. I promise to start sending pics of before and after as soon as possible.
19XX? 20' I/O |
Steve
I had 153 holes in my transom when I re did my boat and none of them are visible and none look like crap. Your gel coat or paint job (maybe the entire transom) will fix that. FellowShip [img]/images/graemlins/wink.gif[/img] |
Ken
Ya 153 holes at least I didn’t have to think much about needing to do a transom job kind a like a no brainer.
Let’s see 8 large holes for twins, 16 large holes for a aluminum transom support type for the transom, 21 holes for 3 transducers most plugged up with 5200, 20 holes for trim tabs, 7 large holes for drainage holes through the transom, 12 small holes for screws on those drain holes, 12 holes for a transom ladder, 4 large holes for the eye cleats on the transom, 5 smaller holes for a 90 degree step on the transom, there were about 8 larger holes that were plugged up with wood and some epoxy, and the rest I am not sure why Oh Yeah I did drill a few myself just to confirm that the water that came out was not good enough to drink. I used most of the holes any way on the glue and screw method of tying the plywood to the transom. I did use 2 layers of glass on the inside first in the rebuilding process of the transom and then filled in all the holes faired it out and painted. FellowShip [img]/images/graemlins/tongue.gif[/img] |
Thanks Fellow-Ship, I'm going to charge ahead this weekend. 153 holes....whew.
19XX? 20' I/O |
