Old 05-11-2005, 01:13 PM
salvagefirst salvagefirst is offline
Default Re: Pin Stripe
if your pinstripe is not too old and cracked up sometimes a heat gun or hair drier will work,if that dont work go to any automotive paint supply storeand get a 3m pinstripe removing wheel and arbor and let the wheel turn into the direction your removing the stripe. And while your in the paint store ask to see the 3m pinstriping book, there are all different stripes, colors and patterns. You can do it yourself follow the directions on cleaning the surface, have the boat in a place with no breeze, pull the cover off the pinstripe start at one corner( i would start at the transom) attatch2 or 3 inches on the corner than walk to the other end unrolling the pin stripe, pull the backing off and do the whole side of the boat at one time, just site down the pinstripe as your laying it, you can pull it back up to adjust it like you want as long as you dont press on the stripe. It looks alot neater than trying to do 2 or 3 ft at the time, that leaves it wavered. Les
Old 05-12-2005, 08:28 AM
MM33 MM33 is offline
3M pinstripe is good quality? thx
Thx,
MM
