Old 05-15-2005, 09:45 PM
Briguy Briguy is offline
Default Re: 1999 225 SUZUKI EFI Problem
Fogger usually fowls plugs. Try another set.
Capt. Brian
Old 05-18-2005, 10:59 PM
Ed Ed is offline
Hey Chris-
Definitely talk to Scott. He has religiously serviced my 225 Suzuki the last couple of years and it runs well. If I had to guess, I would check the following:
1) Trash filter
2) Fuel pumps! The screws holding mine down had worked themselves loose over the years and they just about fell off. If they are loose and you are sucking in air....it might cause a stall.
3) The other thing that comes to mind is the Racor filter. Is it the same as the last one you used??
Ed
