Old 07-20-2005, 08:38 PM
Default Re: SPRAY RAILS
Tim's was on the chine as shown in the pic above. I think thats a good place for it. Someone said that it softened the ride? so maybe you can get that out of it as well.
Old 07-20-2005, 11:38 PM
when strick was ripping off the rails . . . [img]/images/graemlins/smile.gif[/img] I noticed that the fiberglass is much thicker at the chine than two inches above . . . if you mounted them higher then I don't think your boat would hold up very long - unless the rails were very very flexible.
Old 07-21-2005, 11:34 AM
flash14 flash14 is offline
My 23 has them on the chine as well. That is the correct placement for them because of the reinforced corners. The glass has at least 2 extra layers there. I have never installed them on a seacraft, but I have installed them on at least 5 other boats along the chine. Make sure when you soak the teak, that you are patient or else you will have a mess and a waste of a day setting up only to find the wood is not ready for you yet. Good Luck!
