Old 10-26-2005, 09:18 PM
Default Re: My first
thats what i figured. I will make it work where atleast the electrical and hydrolic will stay attached. Theres gotta be a way.
Old 10-26-2005, 10:02 PM
TUGBOAT TUGBOAT is offline
Yep I agree , That would get old Really quick.You'd eventually get leaks . check out the platinum cables from mercury >Not sure what You have but I'm sure theres more out like them.Some 18' ones on e-bay right now. CHEAP so far. Fish ? Whats Dat? [img]/images/graemlins/crazy.gif[/img] Work & Storms, The weather is getting right now.
Scream'n Reels'
Tug. [img]/images/graemlins/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 10-27-2005, 09:24 AM
caper caper is offline
Quick disconnect hydraulic fittings are available - I have used them on brake systems on race cars - to facilitate removal and replacement of rear axle housings. We did not have to bleed the brakes. Sources would be Aeroquip or Wilwood.
Old 10-27-2005, 04:59 PM
all great ideas and thoughts, thanks for that. I am still going to try to have everything stay connected. If that doesen't I will have to get creative i guess. thanks guys.
Hey, another question for ya: If I get a plotter/fishfinder unit can I use my current thru hull transducer or do I have to install another one?
Old 10-27-2005, 07:08 PM
warthog5 warthog5 is offline
Depend's on what unit you have, what unit you buy and if the plug on the end of the cable are compatible.
Old 10-28-2005, 11:15 AM
yachtjim yachtjim is offline
What's the big deal about making the whole thing tilt forward? That is how one of our Seacrafts is set up and there is absolutely no issue with any of the cables or hoses. We are going to make ours powered up and down too. If you already have Bennett Tabs then you can use the Bennett rams. These are special rams for doing stuff like this. You have a lot of weight there so I'm not sure how much lifting power you will need. There are bunch of comapnies that make worm gear style rams too.
www.BOEmarine.com - Marine Electronics and More
www.ByOwnerYachts.com - Innovative Yacht Brokerage Programs
Proud owner of a 1976 23' Seacraft CC.
Old 10-30-2005, 05:43 PM
Here are some more pictures of the gelcoat and the completed project, minus windows, on the boat:
The gelcoat will not be polished. Total time to completion was 1 day to frame, 3 days to glass, and 1 day to gelcoat (2 coats). Not bad for a rookie if I say so. What do you guys think.
