Old 02-22-2006, 10:31 PM
Guest
Posts: n/a
Default Re: Towing Questions
Most every truck/towing vehicle has a manufacturers rating for towed trailers. Also on the title for the boat ,at least in texas, it has the weight of the hull as it came from the factory, the outboard weight is easily found online and the weight of the trailer should also be listed on the trailer title. I would agree that you should have no problem towing with the combo you described, I pull my 23cc with twin 150's 150 gal's of fuel all the gear etc. with our 2wd ford expedition up and over the Galveston causway at freeway speeds {60-65} no problems. Good luck.
