Old 03-06-2006, 10:47 PM
alarie alarie is offline
Default Re: Bennett Trim Tab - Plate replacement Question
G-10 or Garolite is an amazing material for boatbuilding or custom fabrication. You can get it in sheets from 1/32" to 2" thick, solid rods, or tubes (hollow rods). It is basically an epoxy/glass material that is tough and easy to work with due to the extensive shapes you can buy it in.
Make sure if you are gluing G-10 that you sand it up real well, as it has a very smooth, almost glass like surface when you buy it.
Here is a better link for a supplier:
McMaster Carr; G-10 supplier and search for "G-10".
McMaster Carr sells all sorts of stuff, but I mostly buy G-10, plastic sheets or rods, teflon, delrin, wierd SS fastners, titanium, aluminum; all of which you can get in relativly small quantities. Get their catalog if you are so inclined-you will be amazed at what is in there! How about left hand thread, metric hex cap bolts in either SS, zinc plated steel, or titanium!
Peter
Peter Alarie
"that won't take too long, will it?"
alarie404@mac.com
