Old 03-22-2006, 01:16 PM
Bryan A. Bryan A. is offline
Default Re: Cabosil Suplier???
I have sourced a supplier at $78.00 for a ten pound bag, can you beat that? I can't believe you would want to get rid of any. No more future projects? I doubt I will need ten pounds now but it won't go bad and I know I will use the stuff for other projects down the line.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
Old 03-22-2006, 02:27 PM
Trayder Trayder is offline
Velvet Jones
Bryan-
Have you tried LBI Fiberglass up in Groton?
I do not know their price but know they have it in bulk.
Old 03-22-2006, 03:26 PM
warthog5 warthog5 is offline
10lb's would be a 30lb dog food size bag. What in the world would you do with that mutch?
Certinally not for fairing.
I have just about stopped using it all together. Unstaed I use FGCI's 2 to 1 epoxy bonding putty.
I do use a little Cabisol now and then. If I'm spot welding something together. I'll add a little to some 5min epoxy to thicken it up so it doesn't run. then I'll come back and run my fillet's in the Bonding putty right over those spot's.
Old 03-22-2006, 09:51 PM
Trayder - I have not tried them yet but thank you for reminding me they are there. I will check
No I will not be using the whole10 lbs for my current project but I would like to have it around for future projects, wishful thinking. Its the whole buy in bulk theory, You know you buy 30 lbs. of Goldfish crackers at the wholesale price because it is cheaper then when you get home you realize you bought 30lbs of goldfish crackers.
I am realy not sure how much I need at this point.
Wart - What's the advantage of the bonding putty? Less mixing, or air intrusion?
Parker 2530 DVEC
Old 03-23-2006, 12:14 AM
BOTH.
Old 03-23-2006, 09:25 AM
yachtjim yachtjim is offline
Warthog, do you have a link to the manufacturer of that stuff? Or any links to it online? I am making my first "supply run" for materials this morning for my deck project and will ask if they have that stuff.
www.BOEmarine.com - Marine Electronics and More
www.ByOwnerYachts.com - Innovative Yacht Brokerage Programs
Proud owner of a 1976 23' Seacraft CC.
Old 03-23-2006, 11:24 AM
Jim I buy most of my stuff thru FGCI.com
Cabisol is also sold under the name AEROSIL.
Old 03-24-2006, 05:02 PM
resurrection812 resurrection812 is offline
This place down by me in Fl has 10 lbs for $61 and change but not sure on shipping. For bonding and fairing I use Arjay 2001 bonding puddy and fairing compound. It is strong and very easy to work with. Warthog are you familiar with it? Here is the link http://www.fiberglassservices.com/index.htm
1972 23 225 Mariner EFI
