Old 04-05-2006, 10:24 PM
HatTrick HatTrick is offline
Default Re: plug lining
I asked my local boatyard to check out my transom/bilge drain plug and they popped out the old plastic drain and attached a brass fitting to the outside of the transom. The fitting recieves a 3/4 brass threaded plug. If I put my finger in the hole I can feel the plywood in the transom which doesn't seem too right. What should I do to make this hole/fitting/plug etc. be right?
'86 20 ft CC with 4-stroke 150 yamaha
