Old 04-18-2006, 10:39 PM
mjquatt mjquatt is offline
Default Re: repower
My '76 is not a MA. The 55 gal belly tank is a stock tank from West Marine. I would like to go larger but do no have any outlets for fabrication. The original tank was 48 gal.
Old 04-19-2006, 03:14 PM
caper caper is offline
Default Re: repower
If you keep the Seacraft scuppers and original deck height the 20'SC is sensitive to motor weight. That said; 140 horsepower will give about 40 mph w-out a top, 150 probably 42 or 43 mph.
Old 04-19-2006, 09:45 PM
Default Re: repower
Thanks for the numbers. I will keep the floor height the same but am looking at a small design change with the scuppers.
Old 04-20-2006, 04:28 PM
Default Re: repower
MJ - what are the dimensions of that 55 gallon belly tank from west marine? I don't recall west selling any tank of that capacity which will fit into the 20ft seacraft hull.
Old 04-22-2006, 12:40 PM
Default Re: repower
West Marine offers two 55 gal belly tanks. One is by Todd and the demensions are 51"L 25 1/2"W and 16"H. The other is an aluminum tank and it is 48 1/2"L 24"W and 9 1/2"H. Both tanks are listed on page 264 of the '06 catalog.
Old 04-22-2006, 12:47 PM
Default Re: repower
I'm 99.9% sure that neither of those tanks will fit under the floor of the seacraft sf20 w/o raising the floor several inches or grinding down the center stringer.
Old 04-22-2006, 10:43 PM
Default Re: repower
23 1/4" x 90 1/4" x 8 These are the dimensions of my 70 gallon tank in the stock 20 MA.
Do a search on the board for fuel tank Dimensions or maybe someone can post their SF dimensions.
This is hermco's tank on his SF 20.
Old 04-23-2006, 12:15 PM
Default Re: repower
Thanks for the demensions on the 70 gal tank. I still have the floor out of my boat so if I can find someone to fabricate a tank for me I will use that one.
Old 04-23-2006, 02:25 PM
Default Re: repower
The 47 gallon tank that came out of the MA was 23 1/4" x 60 1/4" x 8"
You might be limited by the size of the removeable floor hatch on the SF, so 70 gallons might not fit your boat without cutting the floor. I would highly recommend pulling the tank and measuring it, before you buy/order a new one. It's not worth making a $500 mistake.
If you are located anywhere near Florida . . . Marine Connection Liquidators has some nice fuel tanks for about $3/per gallon.
