Old 05-31-2006, 07:45 PM
Default Re: Prop suggestions 20MA
what's the pitch on your current prop?
Old 06-01-2006, 06:13 PM
Standard Merc SS 19 with very little cup, I did have it out today and ran 48.5 @ 5500/5600 into a slight wind and it has a T Top. Kinda disappointing but I think I'm dragging too much hull
Old 06-01-2006, 10:17 PM
wildlifeone wildlifeone is offline
I got the same problem but no t-top .i do have bottom paint.I dont dee hoe people are getting 57-60 mph out of these hulls? I so far from that it not even funny.Let me know what rpms you get out your props. I will try a mirage 19 soon. and post. Thanks
Old 06-01-2006, 11:14 PM
I think you guys are both being limited by the spark advance module. If someone has 21 pitch prop throw it on, I'll bet you're still turning 5600.
Old 06-01-2006, 11:20 PM
http://forums.screamandfly.com/forum...advance+module
Quote from the Thread: "Take it off the engine, take a hammer and destroy it!!!!!!"
Check your total timing at wide open throttle, set it to 25 degrees and be happy!
Very happy!
The module retards timing(about 2 to 4 deg.) a high rpm, mostly around the 5850 mark.
Acting like a undetected rev limiter.
Take it off!"
Old 06-05-2006, 06:22 PM
I will try a 21, I was amazed it didn't turn a 19 higher, guys are running 19's on 23's.
