I'm guessing you have not mounted the livewell yet?
With a scupper drain problem, you are just increasing the problem with the added weight of the livewell being full. [8.2lbs per gal for saltwater] Move the livewell farther foward. I don't like the idea of using the scpper's as a pick up. It's a "tacky" install. [Is that easy enough on you?] HeHe Livewell pump's have been used as washdown pump's, but they are lousy. A livewell pump is designed to push. A washdown pump is designed to lift. [disphram pump] If you will look at all these pix's of my install, it work's VERY well and is safe, with the Seacock's installed where thruhull's are, unstead of ballvalve's. ![]() No connecting and disconnecting of hose's and crap like that. There is to much going on, on a boat when fishing to have to worry about that stuff. You want to turn a switch on and it work's. Turn a switch off and it stop's. This is the bildge with the seacock's installed. 3/4in intake with bronze scoop and 1 1/2in drain out the transom. ![]() Here is the dualport livewell pump. The top port goes to the livewell and the bottom port goes to the washdown pump. Here is the washdown pump. It then flow's out to the washdown station [squiggy hose] There is a ON/OFF push/pull switch mounted under the washboard beside the washdown station to turn the washdown pump on. This eliminate's having to run foward to the console to turn the pump on. It right there at your fingertip's when you pull the hose out. Plumbing installed. ![]() Livewell is a Kodiak 42-2. It has no exposed hose's on deck. It plumb's thru the bottom for a clean install. That hatch is nick named a NASA hatch and it is the cat's ass. No leak's to the bildge, easy access to the bildge, no working thru leaking piehole's. ![]() ![]() ![]() ![]() Sure it's more work to do a install like this, but look at the outcome. Clean and easy to use. No education required to train your fishing buddies as to what to hook to what. Less crap to worry about and safe. When the boat get's left in the water. Just close 2 seacock's that are easiely accesable thru the NASA hatch. |
Very nice job.
Although I'm now a Mako owner ( formally had a seacraft 20 cc) You have given me some nice ideas to do on my mako. The prior owner had some kind of set up that I still did not understand how it worked so I did the easyest thing, I ripped it all out and am starting from new. The only thing the boss lady asked me was to find a place for some fresh water to wash down when coming out iof the water. I don't think that's a big request from her and it will provide some cool water on those hot fishing days Again Nice Job |
With the water that comes in the scuppers with 2 people back there I thought about just putting a fitting on it and I could wash the whole boat LOL
Okay,
After 2 weekend of tournaments, I have to conclude that these quick disconnect fittings work GREAT!!! It keeps the flow to a minimum on water entering the deck with livewell weight or lard-arse angler weight. During slow trolls, it draws and deck water(or this weekends rain water)out nicely ![]() So here is the deal, - Pick up two 3/4" Bronze thru hulls, mark to length leaving 3 full threads above the nut for screwing on the quick disconnects. I used a double nut to lock on the length and cut slowly with sawzall following the nut. Used a dremel with a stone bit to taper in the end thread to look like the original threaded end. - Duck taped the threads and waxed the duck tape. Applied epoxy covered matt around the bronze thru hulls to make up the diff and cleaned, acetone, wetted out the original holes with epoxy. ![]() - Placed the new thru hulls up through the bottom and waxed the nut and cranked into place. Let cure for a a few days since I was not in a hurry and then take off the nut and unscrew the thruhull out the bottom. Clean/sand area around thru hull and thru hull fittings. - Decided to use quick cure 5200 (or 4200, too late now) the hole and thru hull and snug together. Let dry overnight, and then surprised that I could crank the top nut and into place the mushroom almost flush with hull making sure that the thru hull does not spin to break a seal. I trimmed off the excess 5200 that squeezed out around the thru hull mushroom head. I could put a nice bead around after, but I decided I made enough mess with 5200 so I left it alone. ![]() - Screw on some Home Depot brass quick disconnect fitting with check valve(I noticed Lowe's has a similar one without the check valve) and you are ready to go. If you want them closed, put a brass hose cap on the other male end of the quick disconnect and snap in. Or use the brass cap and take off the quick disconnect and screw on directly. ![]() ![]() Now the livewell, - 1st live well pumps are designed to push water and to be below the water line. So I went with the washdown/livewell pump from shurflow designed to be mounted above the waterline and mounted under the star stern seat with strainer. ![]() - I then decided on just leaving the hoses curled up under the gunnels rather than flush mounting female quick disconnect fittings. Not as clean, but my reason was that I did not want them to leak on the fittings where I could not see and I needed to test and may reroute in the future. Besides sometimes simple is better! ![]() - Layed the livewell on a Home Depot rubber anti fatigue mat(I had to double up the back end with tie wraps to prevent the lower fittings from hitting the splashwell) and when full under weight it is not moving. I mounted a couple of eye bolts in the splashwell area to get some straps, but having the problem to find the correct length. I might go with some rope with spliced eyes with stainless snaps to strap around more to prevent it moving, mainly when empty. If it moves when full, it should be emptied asap!! ![]() Now the washdown; - Picked up a 4' washing machine hose that has the 2 female hose ends. Add 2 male brass quick disconnect to each end and then adaptor to add the female to the nozzle end. Snap in to the outlet hose and start spraying. ![]() - Remove the quick disconnect on the port side scupper to prevent clogging and max outflow and trim over or a lard arse buddy to tilt that side and it works like a charm. And if all of this sounds scary to anyone, I bought a Winslow 4-man offshore raft(only weights 40#!) with Pelican case and mounted in cradle on the hardtop!! ![]() ![]() ( Many thanks again to Jim/Beth at BOE for the raft!!! ….. They are the best!! ) See you in the canyons!! I will be the guy floating in the new raft!! ![]() ![]() - Nick |
Nice install!!
I thought of doing the same thing but never tried. I fixed my original scuppers in a similiar fashion using a through hull like that which I turned on a lathe and a brass tube. It has been good for about 9 years. Thanks for the detailed pics. Good luck in the canyons. ![]() ![]() ![]()
