Old 07-02-2006, 02:57 PM
RODMAN RODMAN is offline
Default Re: starter motor question
If it is possible check the starter draw in amps.High amps ,slow crank = bad starter,normal amps slow crank = battery voltage under 9.5 volts =bad battery.Make sure battery is fully charge and connection are good. Good luck.
