Old 08-21-2006, 12:55 AM
RODMAN RODMAN is offline
Default Re: Inboard running cold
The sender is the temp sensor on the engine,you stated at wot the temp moves,sound like the thermostat is opening to early poss.stuck open a little allowing the engine to run cool.When you had the overheating did you change the thermostat? If not I would do it now.Heard the same on the tuna.
