Old 09-24-2006, 08:30 AM
Default Re: Any Moesly 19' or 20' CCs out there?
RockDoc,
I believe the 20' CC originally came out in 1967. The 19' came out in 1965. The bowrider hull was designed a little differently to give more 'lift' in the bow to compensate for the passenger weight in the bow. The only way you'd find a CC on a 19' hull is if someone cut out the deck & made a CC out of it.
Moesly stayed on with SeaCraft until about March 1970 overseeing the design & construction of the boats, then left. So anything prior to that time could be considered a Moesly built SeaCraft.
David, you've done a fine job in fixing up your bowrider. I am in the process of restoring a 65 Bowrider, outboard, and would like to know more about what problems you found when you tore it all apart. Were the stringers in good Shape? The transom ? I found 'mulch' under the forward bowrider deck and I know the bow deck is not strong, but haven't dug into that yet....Just taking one step at a time.
Appreciate hearing from you.
