Either Lenco or Bennett, right where the arrows point:
i went with what the instructions said on my bennett. it said 1/4 inch above the bottom of the hull... is that the wrong place ??????
When they are retracted the trailing edge of the tab is higher than the bottom of the boat and as said the leading edge is 1/4in higher than the bottom of the boat.
i followed those directions exactly! so i should be ok
Are you indicating an angle to match the strake?
what? im just worried about them being too low on the transom..
1/4 inch up should be enough, all you are trying to do is break the water coming off the transom (like the floats on seaplanes have those steps in them to allow the float to break from the water) they used to recommend that the tabs be mounted flush, good to see they recommend 1/4 inch up
Right Here,
Don't go without them! Scream'n Reels' Tug ![]()
http://www.frenzie.com/frenzielogoline.GIF www.frenzie.com http://www.frenzie.com/custom.htm "Classic SeaCraft" Lures 1983_seacraft_master_angler.]htm My wife and I had words, But I didn't get to use mine."?" |
Display Modes | |
