Old 12-18-2006, 06:19 PM
warthog5 warthog5 is offline
Default Re: battery switch
How about this? I made the size bigger than normal so it could be read easy.
The wire size going to the Power Post/Buss Bar's & Fuse box is sized to handle the load that need's to go there. In this case I used 8ga along with the 30amp breaker.
The ground small ground wire comming from the bottom of the ACR is 14ga
