John, If I recall correctly,
Three wires on the TNT at back of motor from side switch Connect jumper cables to the red and blue wires Blue "sky" up Green Down Red -Hot All you need is a good battery or jump start battery box to make it happen. Good luck . See ya Ken Or loosen the bleed screw located on the starboard side engine mount, through the access hole. It is just below and in between the mounting bolts. Then lift motor and retighten bleed plug screw.
See ya, Ken © |
Display Modes | |
