Old 12-29-2006, 10:07 PM
Default Re: Cold Weather FG Repair
11 cc's of MEK to 1 qt resin above 75 degrees. Under 70 degrees bump it to 13 cc's per qt. of resin. This should give you about 10 mins. or less to work the resin.
The hotter the mix the faster the cure. Try to wait for a warm day or use heat lamps on your work. Humidity also
plays a big part in cure time as well. The slower the cure the better the bond.
See ya, Ken
