Old 02-22-2007, 08:13 AM
Ntrain2k Ntrain2k is offline
Default Re: bait well
You will probably have to use a pump on the drain to pump it out. If you run it to a thru hull above water line it won't back flow in. If it is at or below water line you might need to add a check valve inline.
