Re: 89 23cc fuel tank
I took my tank out in one piece without damaging it.trim the fiberglass back enough so the tank will go thru,its tight but it will go.i cut the foam with a sawsall with a long wood blade. remove the sending unit get a chain and a piece of round steel bar about 2 ft long rapped in a layer of tape to prevent sparks slide it thru the chain link and cross ways in the tank,then hook your comealong or chain hoist to it and pull strait up,believe me it will come up( i used the wrecker)and it wont damage the tank. by the way the tank is flat on the bottom, Les
