Looks Terrific to me
"Bubbles" Maybe your rolling too fast? Maybe the tip method with the shaved bristles like Joey mentioned is your best bet? Some of the cheap foam brushes will break down in the urethane thinners. The ones I use have "JEN MFG" on the wood handle. Get 'em at Ace Hardware. They hold up a little longer. Can several coats of your paint be applied in a single day? If so, then by all means go thinner and then apply a second thin coat after dry/tack up. Also FYI, being painted indoors slows the drying time. Air movement over the paint removes the fumes and quickens the tack up. I know Mike at Wildfire paints inside and uses big fans when he sprays PPG Concept paint. I just hate to steer you wrong Carla as I can only comment based on my experience with the Signature paint application. I'm positive after your all done and made and corrected your mistakes, you'll be a pro !!
