Old 05-05-2007, 09:09 PM
Default Re: Tsunami surgery begins
I'm not quite sure what to do with the blocks of wood that the floor scuppers go through. I've exposed them between the transom and the scuppers....at least 6 inces of them. They were both very wet. I can cut out the section I've exposed but the part that extend under the floor with the scupper through it is probably out of reach. I'm going
to try and remove the brass tudes and see if the wood will pry out. Either way I'm going to epoxy in some PVC for the floor scupper. I plan on having through transom scuppers too....but after washing the boat out a couple of times I like those through the floor too.
