Old 05-16-2007, 12:11 AM
peterb peterb is offline
Default Re: Racor Fuel/Water Filter
My bad. Actually they are Yamaha fuel filters. They have the drain plug in the bottom. Anyone ever deals with these?
Here is a picture of what they look like
[image][/image]
I tried the leftie loosie route tonight and the plug would not turn. Instead the whole unit started to turn.
Should I get an oil filter wrench and then hold the filter still while trying to turn the drain plug?
Any ideas would be appreciated.
thanks,
Peter
Old 05-16-2007, 06:33 AM
The brass plug is tapered pipe thread. It will unscrew from the lower white aluminum cup, which will also unscrew from the filter element. If you remove the brass plug you must prevent the lower cup from turning. There are wrenches available in that shape or a pipe wrench will work. Those are my least favorite design. You can still get 10 micron filtration with a stainless upper housing and clear/blue lower bowl which is more "user friendly" having the pet-cock design drain and is see thru.
Old 05-16-2007, 06:48 AM
Great feedback. Thanks.
If I want to remove the whole filter, it should screw out counter clockwise, correct? Also, If I were to do this where would I remove the sensor cable from?
Old 05-17-2007, 12:38 AM
Fishjack Fishjack is offline
FWIW - that "Yamaha" filter mount and bowl are manufactured by RACOR... not sure about the filter but RACOR probably made that as well (note the "Made in USA" on the filter).. The metal bowls are USCG approved for inboard motor use where as the plastic (blue bowls) are designed for outboard motor applications.
"Anything you let a dog do, you're training it to do." -
1977 23' Superfish
ST250x Yam
