Old 05-27-2007, 06:54 PM
samuelcooper samuelcooper is offline
Default Re: plastic fuel tank source
Thanks, I may be interested if another source from a manufacturer in TN doesn't work out. I live in SC. Your's actually sounds a little better dimensionally. Taller and shorter. But if I don't buy it, I bet someone will. I think this is a common problem if you want a plastic tank since anything but the standard ones are hard to come by.
Way I'm doing mine is to replace the keel. Embedded a new 2 by 4 in epoxy, made fillets and glassed over it. Then I will embed epoxied plywood on top of the keel and to the inside of the hull for a nice bed. Will camber the deck a little. We'll see how it comes out. My boat's name is "Sea What Happens" and that pretty much summarizes my whole attitude here!
You may want to put it in the for sale section of this board. Like I said, I believe it will fit in boats with raised decks.
