Old 06-08-2007, 02:24 AM
Default Re: Installing a bracket
2.5 inches would be the starting point with the 30 inch set back. You may likely have to move it higher so make sure you have room to move the motor up. My anti cavitation plate about 4.5 inches above the bottom of the keel.
Old 06-08-2007, 10:23 AM
JohnB JohnB is offline
Thanks,
I talked to Armstrong, and they said the top of the bracket should be 23" from the keel, and that would put the motor where it needs to be. Most of the pictures I have seen are close to this, it puts the bracket about 1-2" below the top of the trim tab mounts, which is going to be a pain to work around.
JohnB / 23' SeaCraft
Old 06-08-2007, 11:22 AM
JW-Tex JW-Tex is offline
If they are Bennett tabs I think they have shorter hydraulic cylinders availalbe if that helps.
Old 06-08-2007, 12:09 PM
Thanks,
I just got off the phone with tabman/aka Tom, and he suggested I look at the short ones, they are 2" shorter that the standard ones. I also have the 9x17 which overlap one of the chimes, so I am looking at the 12x12.
Anyone use the shorter accutators? and what are most of you running for tabs, 12x12" ?
Old 06-08-2007, 12:43 PM
John
I switched out the standard actuators for the short ones on my bracket install. The Potter Bracket sits lower than the Armstrong so the small ones would fit nice and snug underneath for you. I still had to cut out a small section of the bracket. I also use the 12"x12" tabs
Old 06-08-2007, 04:01 PM
Thanks,
Your boat looks sharp. That bracket has a little bigger "chamber" then the armstrong, but it looks like it is within an inch or so of where they say to mount it (23" above the keel). Did you delete the drain plug?
Also, do you have any pictures of the inside of your transom, how it's laid out?
I am planning on putting a livewell back there on mine.
Your tabs are not "flush" with the bottom, is there a reason for that?
Old 06-08-2007, 05:50 PM
Yes, Being on a lift makes plug access impossible. A custom garboard drain was fashioned thru the keel with access via the transom door for bilge draining.
Go to the 23' models and view shots of the transom redo.
Click Here---> Transom redo
They are flush (up approx 1/8"), the camera angle confused you...
