Old 06-08-2007, 05:50 PM
Default Re: Installing a bracket
Did you delete the drain plug?
Yes, Being on a lift makes plug access impossible. A custom garboard drain was fashioned thru the keel with access via the transom door for bilge draining.
do you have any pictures of the inside of your transom, how it's laid out?
Go to the 23' models and view shots of the transom redo.
Click Here---> Transom redo
Your tabs are not "flush" with the bottom, is there a reason for that?
They are flush (up approx 1/8"), the camera angle confused you...
