Old 07-03-2007, 08:53 AM
bdolnik bdolnik is offline
Default Re: 77 23' Savage
I'm in Satellite Beach (on the East Coast south of Cocoa Beach). The boat is at a marina in Palm Bay, will be kept in a water slip. Should be about a 20 minute run to Sebastian Inlet from there
Would love to attend the next Florida gathering as long as I can get to it by water, don't have a trailer.
Old 07-03-2007, 10:20 AM
Hey Bryan,
We have quite a few CSC people in East Central.
Capt. Brad is in Melbourne, Capt Lloyd is in Merritt Isl.
I'm right on the Volusia/Brevard line.
Capt Chuck is in Stuart and 65 Bowrider in N Palm Beach,
plus there are a bunch more. Maybe we should plan a
Brevard are get together.....
Good Luck with the Savage. Ken
Old 07-03-2007, 11:19 AM
We have quite a few CSC people in East Central...
A whole bunch of us Seacraft owners here in Brevard. Well hopefully I'll get to use mine soon! I can't wait to get it going.
Old 07-04-2007, 05:38 AM
doodlebug doodlebug is offline
Ken,where is it going to be and when,The tall one only
camps in hotels or the motor home and it's ready to go
1979 23 SCEPTRE TWIN 150 Opti's/GAUSE BUILT BRACKET
Old 07-04-2007, 08:13 AM
Ryank Ryank is offline
That is defintely not the boat I was looking at, The one I considered was white and it was running, But you have a great boat there! I hope you got a good price on her, and I hope you show us pictures once you're done! Congrats!!!
Seacraft's for life !!!
Old 07-04-2007, 10:22 AM
Ok NoBones...you just committed to organizing a gathering on THIS SIDE of the state.
Just tell me WHEN & WHERE...WE'LL BE THERE!!!
Old 07-07-2007, 03:53 PM
Spacers.......on inboards and I/Os the engine is down in the hull.....the exhaust manifolds have risers on them...they go up...and then down to the exhaust...through the prop usually for an I/O, or through some muffler system and transom for an inboard. The spacer raises the height of the riser even higher....that's so a wave doesn't force water into the engine through the exhaust...there are flapper valves in the exhausts as well....but it's all to keep that evil water out.
Old 07-03-2007, 10:24 AM
Gary Hill Gary Hill is offline
BRAYND,
The easy way here is buy the long block and rebuild the carb or buy new. Fresh water cooling is a good way to go, it saves the engine, two years ago I put in a new engine and trans. looking back I would have just had the trans rebuilt, I gave the whole works to a friend of a friend for his SEACRAFT and he has done nothing with it, but it was fresh water cooled and still a 76 unit running good. I was going to pull the motor and update it, when my wife said, "what are you stupid", I made the comment if I had to pull the engine/trans I would put a new engine/trans in. I put a new unit in and I put 3" spacers in to help keep out water ingestion into the engine, I think is the way to go. I went from a 351 233 to a 350, 315 hp good move so far, I have two friends each with 225 four sroke on 23 foot boat's and while running at 3200 rpm I get the gass milage they do.
GARY
76 SEACRAFT CC INBOARD
Old 07-03-2007, 11:21 AM
I bet I'm going to have a BUNCH of questions for you First off what does the 3" spacers mean?
The motor I'm looking at is a 350 carburated rated at 300hp. I could go fuel injected for an extra $1000 or so and get 330hp. I think I like the simplicity of the carb though.
Old 07-09-2007, 06:09 PM
GetReel GetReel is offline
Good luck. Having gutted a 1975 IB which is basically the same setup, I can respond with some experience:
Tanks under aft deck, 2 @ 50 gals +/-. If original replace. Keep them for fabricator to use. They are in tight and you may want them to be made 1/2 shallower because the decks sometimes ride on them. Also moisture collects under them so get expoxy coated tanks.
Drain plug is where you found it, not easy to get to. I suggest a rear bilge pump also near shaft log.
Your shaft should be 1 and qtr inch, if original, could be an issue with new engine torque....
If you can afford it, get a new bob-tail fuel injected engine. Also check and make sure that the EFI engine has a "cooling pot" for the hot unspent fuel to return to...
Most trans are 1 and a half turn. By the time you find everything to replace, easier and perhaps cheaper to go all new. Also, this is a heavy boat and you may want the EFI to save fuel.
Original engines were mostly Ford 351's, mine came with it.
Good luck, great boat.
