Old 07-16-2007, 07:23 PM
Default Re: New England Folks - Cape Cod gathering ???
You guys better pick a date soon or the ice will be moving down
Old 07-17-2007, 01:24 PM
oldbluesplayer oldbluesplayer is offline
I think everyone's gone fishin' !!
Old 07-17-2007, 10:27 PM
Or now that K-Mart owns Sears, the catalog is takin' longer to go through
Go ahead Bill, set a date and a place and go with it.
Good Luck, Ken
Old 07-18-2007, 01:34 PM
Well, I'm down for a bit, for some possibly serious engine maintenance - gotta pull a head off and see what caused a sparkplug gap to get closed up, electrode pushed in.
Worst case, a rebuild, probably be out 2 - 3 weeks (I've done a lot of motor work in my life)
I'll let anyone else take the lead on this.
Bill
Old 07-18-2007, 06:57 PM
Sounds like wrist pin or rod bearing.
Compression test should tell if it is top end or bottom end.
Good Luck with it Bill, Keep us posted.
Ken
Old 07-20-2007, 04:24 PM
Ken, et al -
I believe I got lucky, it was a soft hit, probably carbon, that pushed in the electrode. Con rod bearings are fine, compression is good, 115 - 120 all cylinders, visual examination shows everything good, closed it up and ran it on muffs - sounds just fine.
Goin back in the water - just not this weekend - I'm off to the Vineyard for the shark tournament !!
Bill
